Group: DynoMotion Message: 14915 From: tesotronics Date: 7/10/2017
Subject: Calling console script commands in C code
I've been going through the KMotionDef.h file and I noticed not all the commands that are on the script command page are available in C.
I need to make a call to SetFRO<> from my C-code.
I hope a solution exists for this, I assumed this was possible when I decided to use Dynomotion for my machine (WEDM machine). If not, I can scrap my KMotion+Kanalog and start searching for another control solution...
Group: DynoMotion Message: 14916 From: Tom Kerekes Date: 7/10/2017
Subject: Re: Calling console script commands in C code
See these functions listed in KMotionDef.h
